ParadiseMJ Posted February 21, 2011 Share Posted February 21, 2011 Last week I finished my harmonic balancer install and it went fairly well. I had not torqued it down because it started raining and I figured I'd just finish it the next day. So my problem is it WON'T torque down. It just spins. I noticed that the end of the bolt is chewed up. Can I use a shorter bolt or should I re-tap the crank snout...and if so should tap it 1/2" x 20 or?? Any answers? I wanna drive the mutha'. Link to comment Share on other sites More sharing options...
Eagle Posted February 21, 2011 Share Posted February 21, 2011 Is the damper fully pulled into place? I suspect your mistake was using the original bolt to try to install the damper. It's a press fit, and it needs the bolt to pull it onto the crank snout. But ... the original bolt is too short, resulting in a stripped end. The correct procedure is to use a longer bolt to draw the damper onto the crank snout, then replace with the original bolt for final torque-down. If the bolt is tripped, chances are the crank is okay and just needs the threads chased out. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted February 21, 2011 Author Share Posted February 21, 2011 Is the damper fully pulled into place? I suspect your mistake was using the original bolt to try to install the damper. It's a press fit, and it needs the bolt to pull it onto the crank snout. But ... the original bolt is too short, resulting in a stripped end. The correct procedure is to use a longer bolt to draw the damper onto the crank snout, then replace with the original bolt for final torque-down. If the bolt is tripped, chances are the crank is okay and just needs the threads chased out. I used a longer bolt with about 7-8 washers. I did not use the original bolt. When the snout was about 1/2 inch from the HB seating, I inserted the original bolt. It's NOT stripped until you get to the end of the bolt itself, then the bolt is chewed up. How do I "chase out" the threads. Link to comment Share on other sites More sharing options...
JeffN Posted February 21, 2011 Share Posted February 21, 2011 get a bottoming tap the size of the factory bolt and run use it to "chase" repair the threads Link to comment Share on other sites More sharing options...
