Startere issue
Ive been dealing with this problem for a bit..
when I go to start my MJ there is a horible sound comming from the starter.
At first I thought it was the gears getting all chewed up, but the battery just died and i went to crank it over and while it was cranking slowly (not enought to turn over) there was no noise or clashing.. al least one full engine turn.
So i decided that the noise I am hearing is something electrical?
can anybody confirm this or not?
Is there anywhere to look other than the starter?
  Chuck said:
Sounds like your starter will need replacing. Best way to make sure is to use a set of jumper cables from a good battery just to make sure your battery is not going bad.
Chuck
1989 Comanche Pioneer
:hateputers:
good idea!! :cheers:
