Gauge swap revisited 4 to 6 cyl clusters
I have an '88 MJ 4 bngr.
I want to swap out the dummy light cluster for a gauge cluster. I have a cluster from a '90 and I know HOW to swap it.
BUT the senders are giving me a fit.
I found a GAUGE specific coolant temp sender for the '88.
With the oil pressure sender I cannot find a GAUGE sender until 1991. I am sure it will fit...but I don't know if it will work and I don't want to waste $34 to find out.
Does anyone here know if the '91+ sender will work? It has a single blade type connection so again I know it will FIT...
Thanks...I think I may have answered it myself as well...
Realizing the parts store has more 'stuff' listed for XJ's I did a search for the oil sender for an '88 XJ (well...for my '90 XJ first) and sure enough...they have a GAUGE sender listed.
SO I guess I will see if it works. It is the same PN as the '91-?
Anyone else able to confirm?
