New gas tank mount
If you're j-bolts or j-bolt hangers ever break, here's my fix.
Did this with the bed off.
Cut out the hangers, drilled 1/2" holes through the bed and dropped in 8" 3/8 carriage bolts.
Definitely put a piece of iron in between the bolt heads and the bed floor.
Secured the carriage bolts snug against the bed with a nut so they wouldn't flop around and then just a flat washer and lock washer to hold the strap nut in place.
