4.0 oil leak fix?
Found this on allpar.com. In case you have a 4.0 oil leak that is escaping detection and don't know this already:
"I owned a 1992 Cherokee with a 4.0 I-6. It had constant oil seepage from the rear of the engine. My dealer replaced the plastic valve cover with a die cast aluminum one with no success. I finally traced the oil to the oil filter mount. The o-rings that seal the oil filter mount are Nitrile (aka Buna-N, NBR) which have limited life. Replacing the o-rings with the same size but with 70 Durometer Viton rubber solved the leakage. My fix lasted the life of the vehicle."
