Alternator
Hit all of them with some PB Blaster before you get at them so they turn smooth. The long adjuster bolt should definitely get a spray.
yea its help alot but now I don't use the adjuster anymore and use prybar method and pry the power steering metal mount then tight the lock nut. Its alot easier for me than loosen or tighten the adjuster bolt.
