comanche12 Posted December 14, 2010 Share Posted December 14, 2010 while I was work on passenger brake line few days ago, i notice that vacuum line(tan or white,green and yellow) r jammed in LCA bracket so I pulled it out and its not even plug in. I'm sure its for climate control vacuum system but where should it plug at? :hmm: and this blue line been blocked with a screw in it while i was work on blower motor before work on brake line edit: ignore the blue WIRE its vacuum hose next the wire though Link to comment Share on other sites More sharing options...
juan Posted December 14, 2010 Share Posted December 14, 2010 Those are for your front axel CAD. (central axel disconnect) Your front dana 30 has a two shaft design in the passenger side that disconnect the outer shaft from the inner shaft. It works with vaccum and when connected and working is what gives you four wheel drive. Link to comment Share on other sites More sharing options...
jimmy21669 Posted December 14, 2010 Share Posted December 14, 2010 Those are for your front axel CAD. (central axel disconnect) Your front dana 30 has a two shaft design in the passenger side that disconnect the outer shaft from the inner shaft. It works with vaccum and when connected and working is what gives you four wheel drive. Unless your front axle was replaced with a non-CAD axle. Link to comment Share on other sites More sharing options...
comanche12 Posted December 14, 2010 Author Share Posted December 14, 2010 ah thanks so i would just leave like that since i got axle swapped with non cad? (79 bronco hp d44) Link to comment Share on other sites More sharing options...
