tazer15 Posted December 5, 2010 Posted December 5, 2010 i need the trim pieces that go around headlights turn signals etc for 91thru96 header panel. i also need the side marker/turn signal lights themselves also.
ComancheAssault Posted December 8, 2010 Posted December 8, 2010 i need the trim pieces that go around headlights turn signals etc for 91thru96 header panel. i also need the side marker/turn signal lights themselves also. Would like to help out;Try carpartswholesale.com, they got loads of often miscellaneous parts that are often hard to find. I once found lots of headlights, Side Marker Lights , turn signals, header panels for various trims of them old models.Key in your car details for a better result on their product roll-up. Good luck.
