2 ford D44's 1 BUILT, 1 stock, for MJ/TJ/XJ/ZJ and a 9in! GA
Huntingman2706217
ones built with 5.13 gears, ARB air locker with new pump and all wiring and such, chromo inner and outer shafts, trussed, high steer, new warn hubs, traingulated 4 link setup and setup for hydro steering (not included), came from a 79 F250 8 lug ford... was built and removed from a XJ...
also have a stock 76 F150 5 lug D44 HP with weld on perches and still have the radius arms (ive got this one listed elsewhere yes)...
Both axles $1000 firm... you can't build this axle for double this cost...
i also have a ford 9in i got stripped down and welded on Ruff Stuff simple axle swap to it for a XJ... i have 5.13 gears for it and a full spool... also have brackets to convert it to disc brakes... just needs everything put together... is a 31 spline 9in... only need a install kit and put it together... kind would like to sell it with the 79 axle but i will sell it by itself ONLY after the 79 has sold... if the 79 axle sells then I'm out of jeeps and going to find another old chevy to restore... i miss having a muscle car bad... ill just buy a cherokee later thats already done...
Archived
