aabmike Posted October 18, 2010 Share Posted October 18, 2010 Has anyone done the 97+ door upgrade with power windows and locks? I bought the doors, but I need to know if I can just run some wires with inline fuses to them to make the windows work, or is it more involved than that? I couldn't find any manual window doors for what I wanted to spend, so I am kind of stuck with what I bought now. :???: :doh: Link to comment Share on other sites More sharing options...
Garvin Posted October 18, 2010 Share Posted October 18, 2010 You can run lines with fuses in it, the only diff is you can use them all the time instead of just when the key is on. I ended up doing that on my old Sable when I added power windows and locks to it. To make it simpler, you can get the switches from a 2dr Cherokee then just run the lines from there. It'll help if you can find a wiring schematic since the lines need to go from one door to the other. Link to comment Share on other sites More sharing options...
