putting tranny back on ????
last night I changed my clutch and when I went to put the tranny back in it won't any closer then an inch from the block
I tried turning it to ''line up the splines''
its in line with the block but :dunno:
any advice, inputs or comments
I'm kinda of in a blurr about this
I can't seem to find why i won't go back on
The splines are not lined up or the input shaft is not oriented correctly for the tranny input shaft to slide into the flywheel correctly. I went thru this exact issue when replacing the internal slave cylinder on my 89 and it took a lot of wiggling/wrestling the tranny to get it to finally go the last inch or so.
My problem was that the tranny was not at the right angle, if it is just the splines being off, you can put it in gear and turn the output shaft to align them, it has to be at just the right angle though for the input shaft to slide into the flywheel.
stupid me I had the right angle and everything ..............
the CPS fell between the pressure plate and the tranny has I was putting it back on :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool: :fool:
