dasbrick Posted August 2, 2010 Share Posted August 2, 2010 Hey i got a problem for yalls I got a horrible squeaking from the rear, almost like metal on metal scraping/squeaking but only when I am turning. if it was the front, I'd say hub, but whats on the rear that could cause this? Link to comment Share on other sites More sharing options...
deziped Posted August 3, 2010 Share Posted August 3, 2010 Is it coming from one side or center? Does it do it when turning either direction? Got a bad axle bearing maybe, or loose axle, brake spring loose? Probally have to disassemble sum-thun to find it. Link to comment Share on other sites More sharing options...
dasbrick Posted August 4, 2010 Author Share Posted August 4, 2010 One side by the sound of it, rear drivers, and only on a left hand turn. Update: Tore it open today. Axle bearing seemed good and snug with no play. The self adjuster cable was broke. Could this be the culprit? Link to comment Share on other sites More sharing options...
