I posted in your "other" tread.
Have you changed the fuel filter????
Didn't see your mulit topics running :roll:
The Book says.........At idle, the pressure should be 14-15psi. If the pressure is not correct, adjust the pressure regulator to obtain the correct fuel pressure. Turn the screw at the bottom of the regulator inward to increase pressure or outward to decrease pressure.
Note the above is for the 2.5 engine, and while the engine is running and idling.
From what you write, your with-in spec's if the engine was running.
