mikeviera Posted May 13, 2010 Share Posted May 13, 2010 I have a 1988 4x4 I6 jeep comanche.... I am going to replace the Valve cover gasket. Would anyone happen to know what the torque specs are? I went through the search to see if anyone had posted anything and couldn't find it. I am a noob to the forum... if there is anything else that i need to add, just let me know... Thanks in advance. Link to comment Share on other sites More sharing options...
Yesterday's Danish Posted May 13, 2010 Share Posted May 13, 2010 Haynes manual says 28 in-lbs if you're using RTV or 55 in-lbs if you're using a permanent gasket. Or do what I did and snug them up with a 1/4 inch ratchet. :thumbsup: Link to comment Share on other sites More sharing options...
mikeviera Posted May 13, 2010 Author Share Posted May 13, 2010 thank you for the info :cheers: Link to comment Share on other sites More sharing options...
Wildman Posted May 14, 2010 Share Posted May 14, 2010 And add.........after you run it a few time, cold/hot/cold, check the torque, them little 1/4" bolts like to work loose real easy :fs1: Oh, and welcome newbie :waving: Link to comment Share on other sites More sharing options...
Zsketch20 Posted June 7, 2015 Share Posted June 7, 2015 Thanks guys. Link to comment Share on other sites More sharing options...
