xflowdaboi352 Posted April 6, 2010 Share Posted April 6, 2010 4wd won't in enage pulled it apart the fork is not broke it moves when u pull the lever front drive shaft spins any ideas 1988 mj 4x4 4.0 auto Link to comment Share on other sites More sharing options...
Automan2164 Posted April 6, 2010 Share Posted April 6, 2010 What are you basing this off of? The presence of the light? Rob L. Link to comment Share on other sites More sharing options...
Eagle Posted April 6, 2010 Share Posted April 6, 2010 4wd won't in enage pulled it apart the fork is not broke it moves when u pull the lever front drive shaft spins any ideas 1988 mj 4x4 4.0 auto What fork are you referring to? What do you mean the front driveshaft spins? Does that mean when the vehicle is moving the driveshaft turns but isn't driving the front wheels, or does that mean when the vehicle is in 4WD and parked, you can reach under and turn the front driveshaft by hand? Link to comment Share on other sites More sharing options...
