smithe1811 Posted April 6, 2010 Posted April 6, 2010 Gonna need to replace my brake lines soon and was looking for some opinions and suggestions on type and length and brand. i have an 88 swb with a 4 inch lift, looking for front and rear lines. Thanks Erik
Eagle Posted April 6, 2010 Posted April 6, 2010 Are you asking about the steel hard lines, or the rubber flex hoses?
smithe1811 Posted April 7, 2010 Author Posted April 7, 2010 well, both i guess. I'm looking for info on which are better based on experience. i know nothing of them. :cheers:
smithe1811 Posted April 9, 2010 Author Posted April 9, 2010 are these ones any good? http://www.crownperformance.com/jeep19fr06.html
High2by Posted April 9, 2010 Posted April 9, 2010 Up front I'm running Rubicon Express extended SS lines.http://www.rubiconexpress.com/JeepParts/Product.aspx?folder=JPBL&part=RE1553 The drawback to SS is, if you ever needed to "crimp" a line to get off the trail it's hard to do. The rubber lines are more forgiving that way. A pair of vise grips and you have brakes. If I had to do again, I would run longer rubber lines. Rough Country also has a set. http://www.roughcountry.com/jeep_xtras_ss-brakelines.html I don't know the part numbers for longer rubber lines. I know some year models of Dodge 1/2 ton trucks use some long lines.
Backroads Posted April 10, 2010 Posted April 10, 2010 the hardlines are 3/16" your gonna just have to bend and flare your own. I got 25' spools of line from my local autoparts store. Another option for front brake lines are lines from a WJ, reasonably cheap, and a bit longer than stock.
