Brake lines?
Up front I'm running Rubicon Express extended SS lines.http://www.rubiconexpress.com/JeepParts/Product.aspx?folder=JPBL&part=RE1553 The drawback to SS is, if you ever needed to "crimp" a line to get off the trail it's hard to do. The rubber lines are more forgiving that way. A pair of vise grips and you have brakes. If I had to do again, I would run longer rubber lines.
Rough Country also has a set. http://www.roughcountry.com/jeep_xtras_ss-brakelines.html
I don't know the part numbers for longer rubber lines. I know some year models of Dodge 1/2 ton trucks use some long lines.
