88 Beast Posted March 23, 2010 Share Posted March 23, 2010 Burning some vacation time, so decided to work on the beast. Fixed no start problem, turns out update to CPS harness was done back in the day and soldered harness connection was badly corroded, easy fix :banana: Replaced leaking p/s pump and leaking freeze plug, a royal PITA with a header tube in the way. Found a broke motor mount too. Now for the cooler lines, the're all leaking at the connection to the front cooler tubes. I can get new lines but they don't come with the plastic seal that goes on the cooler connections at the radiator area. Maybe just need to replace the seals? Napa and Autozone aren't much help. Are these seals dealer only parts? Just Empty Every Pocket :shake: Link to comment Share on other sites More sharing options...
Wildman Posted March 23, 2010 Share Posted March 23, 2010 Check Rockauto.com They carry the quick connect fittings. Link to comment Share on other sites More sharing options...
