jeephack Posted February 25, 2010 Share Posted February 25, 2010 After getting all of the lights functioning properly, I decided to work on a couple of small electrical problem under the dash. After pulling things apart, I have a question that I have never thought much about before. You guys probably know instinctively, but it is something that I have never given any thought to. With the electrical connectors disconnected from the cluster, should all the gauges be at zero, or do they just stop at an arbitrary position? The reason I ask is, with the gauge cluster lying on the front seat, I am running at about 150 degrees on the temp. gauge, I have 20 psi oil pressure, and 1/2 tank of fuel. Is this normal? Link to comment Share on other sites More sharing options...
jpnjim Posted February 25, 2010 Share Posted February 25, 2010 Yep. They all do different things when you pull them. & hooking the temp & oil pressure gauges up to the idiot light senders will max them out. Link to comment Share on other sites More sharing options...
jeephack Posted February 25, 2010 Author Share Posted February 25, 2010 Thanks. That's what I thought but I wanted confirmation. Link to comment Share on other sites More sharing options...
