Front drive shaft...
The 2.5" 4 spd manual Comanche I bought doesn't have a front shaft. Is it double cardan?
From my measurements it appears to be 26.5" from center yoke to center yoke. Can someone confirm this for me. :) Please
Also if you have one please sell it to me for cheap :clapping:
What year are you talking?
84-86 used a flanged CV joint to mount to the T-case. 87+ got a double cardan joint with the 231.
Does your T-case have a flange, or a yoke?
If you have the yoke, you can grab a front shaft from any 2.5 manual XJ/MJ. Automatic shafts will be a different length, as will 4.0 shafts.
