A_Town_MJ Posted January 22, 2010 Share Posted January 22, 2010 3" in Rought Country Lift off of 2000 Jeep Cherokee + the front coils. everything but shackle bushings. for 150$ & 93 Xj 4.5" leafs skyjacker. just leafs, for 75$ Which if either would bolt up to my MJ. Thx in advance Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 If they're complete replacement leaves for the XJ, they will not bolt onto an MJ. AALs for XJs won't do much on an MJ. As I'm sure you know, everything up front is the same for XJs and MJs. Link to comment Share on other sites More sharing options...
A_Town_MJ Posted January 22, 2010 Author Share Posted January 22, 2010 If they're complete replacement leaves for the XJ, they will not bolt onto an MJ. AALs for XJs won't do much on an MJ. As I'm sure you know, everything up front is the same for XJs and MJs. AALs?? what do you mean by that??? So just to be clear the 4.5 skyjackers won't work? Link to comment Share on other sites More sharing options...
Geonovast Posted January 22, 2010 Share Posted January 22, 2010 AAL is Add A Leaf. It's just a single leaf that you add to your existing springpack. If the 4.5" is a full leaf replacement, which I'm sure it is, it will not work on your MJ. MJ leaves are considerably longer. Link to comment Share on other sites More sharing options...
A_Town_MJ Posted January 22, 2010 Author Share Posted January 22, 2010 Dang i knew it was to good to be true, thx for the info. :D Link to comment Share on other sites More sharing options...
