man of la manche Posted July 15, 2009 Share Posted July 15, 2009 I have a set of 95 xj doors with power windows that I am going to put in my 88 manche, however, the power windows have a light blue factory tint and I would rather use the glass from my 88 manual doors can anyone tell me if the glass is the same shape (I assume that it is) and that the glass from my older manual doors will go into the power doors? does anyone have any tips on removing/replacing the glass in the doors? Link to comment Share on other sites More sharing options...
Wildman Posted July 16, 2009 Share Posted July 16, 2009 The glass should be the same.......the only difference is the regulator. I dug up a couple "old" topics on this, the 2nd one give you some info on removal of the glass bolt. viewtopic.php?f=2&t=15549&hilit=glass+replacement viewtopic.php?f=2&t=7245&hilit=door+glass here's one article that I found that just might get you thru what your doing......and with pictures :yes: http://www.lunghd.com/Tech_Articles/Bod ... or_Fix.htm Link to comment Share on other sites More sharing options...
man of la manche Posted July 16, 2009 Author Share Posted July 16, 2009 thanks!!! the 2nd link is exactly what I was looking for Link to comment Share on other sites More sharing options...
