so, I had an odd high speed cutout problem. I'm pretty sure now that it was the fuel pump. Problem is that I went "hell or high water" with it last night. I held my foot to the floor after it started bucking to see what would happen. She didn't like that, what ended up happening was me killing the motor, and having it towed to the house. So now it doesn't start. Here's the run down.
In the past 2 weeks I've replaced all th tune up items.
Cap, rotor, wires, plugs, air fuel and oil. Last night I replaced the o2 sensor.
I'm pretty sure that I've cooked something in the fuel pump circuit. If I turn on the key I get no noise from the tank. I also don't hear the relays click under the hood. I also smelled the smell of burnt electrical components in the battery area last night. Which fusible link powers the fuel pump?
I know the motor has spark, I get spark from the ignition module to the center of the cap.
