Automan2164 Posted July 14, 2009 Share Posted July 14, 2009 buddy208 said: also want to know if 3.56 gears would be enough for 31" tires with a 4.0 Worked for me fine. I ran that combo for a few years. Better than 3.07's... :ack: Rob L. Link to comment Share on other sites More sharing options...
buddy208 Posted July 14, 2009 Author Share Posted July 14, 2009 buddy208 said: i need to know if a jeep wrangler front axle will fit my comanche and what year the wrangler has to be, also is a 2wd axle different from a 4wd cause i looked around and the 4wd axles are bigger than my 2wd. still need to know about this stuff Link to comment Share on other sites More sharing options...
Automan2164 Posted July 14, 2009 Share Posted July 14, 2009 buddy208 said: buddy208 said: i need to know if a jeep wrangler front axle will fit my comanche and what year the wrangler has to be, also is a 2wd axle different from a 4wd cause i looked around and the 4wd axles are bigger than my 2wd. still need to know about this stuff '97 up axles off of a TJ will bolt in. YJ's are spring over. It will work, but not without welding and work. Should be same size throughout. 2WD axles are different that 4WD axles. But generally 4WD axles go right in. Rob L. Link to comment Share on other sites More sharing options...
buddy208 Posted July 14, 2009 Author Share Posted July 14, 2009 automan2164 said: buddy208 said: buddy208 said: i need to know if a jeep wrangler front axle will fit my comanche and what year the wrangler has to be, also is a 2wd axle different from a 4wd cause i looked around and the 4wd axles are bigger than my 2wd. still need to know about this stuff '97 up axles off of a TJ will bolt in. YJ's are spring over. It will work, but not without welding and work. Should be same size throughout. 2WD axles are different that 4WD axles. But generally 4WD axles go right in. Rob L. thanks Link to comment Share on other sites More sharing options...
