Memory wire/Batt slot
Well i went to put a new radio in the truck and when i tested the wires just to make sure everything worked, the wire for the memory that comes from the battery had no power but the wire from the ignition switch worked fine? so i checked the batt slot on the fuse box and got the same thing. Is there a fuse under the hood or a fuseable link i need to track down?
