90MJext Posted March 28, 2009 Share Posted March 28, 2009 This was done on a '97 ZJ overhead console. The purpose is to more light into the interior without spending a lot of money. Parts needed console phillips screwdriver (to remove console) soldering iron solder LED panels, http://cgi.ebay.com/12V-Super-White-115 ... m153.l1262 shrink tubing Torx T10 bit plastic epoxy wire strippers needle nose pliers 1. I removed console from headliner. 2. I removed light housing from console, Torx T-10 bit, there are two screws on the front housing and three on the rear. Image Not Found 3.I removed the bulb. I used needle nose pliers remove the bulb contacts had to press in the sides. Image Not Found Image Not Found 4. I placed a LED panel into housing, running wires out the backside of the housing. Image Not Found when you are satisfied on the positioning, use a epoxy to hold it. 5. When I was doing the front housing I had to remove a section. before on the right, after on the left Image Not Found 6. I let the epoxy cure and then reattached the housings. 7. I cut the bulb contact off, and stripped and tinned a section of wire for each of the contacts. For the front the wires were 2 grey (switches) and 1 pink, the rear were 2 grey (switches) and 1 grey going towards the front. 8. I soldered the red wires together and to the pink wire (front) and single grey wire (rear). I soldered the black wire to the appropriate grey wire and shrink tubed all connections. front: Image Not Found rear: Image Not Found 9.Reinstalled the console. front Image Not Found rear Image Not Found rear hatch light (not done yet) used for comparsion Image Not Found results:the interior is a lot brighter and only spent $2.00 (w/o shipping) for LEDs and little bit of time. Link to comment Share on other sites More sharing options...
BBCchris Posted March 30, 2009 Share Posted March 30, 2009 Huh... Thats pretty cool. Link to comment Share on other sites More sharing options...
