Side window replacement?
Are you asking about the big window or the little wing window? The big one is easy: remove the door skin, lower the window until you can get to the nut that holds it to the mech. remove the nut, and spring washer (little wavy washer behind the nut), then, up on the front of the door, there are 2 phillips head screws to remove. Next, go back to the lower front part of the door and you will see a hole about 1" diameter. Inside the hole there is a10mm bolt to remove. Pull the weatherstripping off of the door, then tilt the wing window back to allow the main glass to be removed. If you need to pull the wing, do all of the above, then, pull the wing window up/out until you feel it get caught in the frame. If you look inside through the top, you can see how you will need to turn the wing glass frame to finish removal. Install is the reverse, of course.
