trail grenade Posted March 15, 2009 Share Posted March 15, 2009 i was rele looking into the motion offroad HD steering conversion but i started looking through jeeperz creeperz site and found this rugged ridge conversion which is noticably cheaper i was just wondering if anyone has used this crossover 1 ton steering conversion and antidisestablishmentarianism results u had with it? Link to comment Share on other sites More sharing options...
comanche13 Posted March 15, 2009 Share Posted March 15, 2009 I'm pretty sure its the same steering system... Link to comment Share on other sites More sharing options...
trail grenade Posted March 15, 2009 Author Share Posted March 15, 2009 oh ok thanks ive heard some people over at pirate talking about needing spacers to compesate for steering roll does this depend on how much lift u have? Link to comment Share on other sites More sharing options...
comanche13 Posted March 21, 2009 Share Posted March 21, 2009 i havent heard anythign about that...i think it just bolts in Link to comment Share on other sites More sharing options...
wolfpackjeeper Posted March 21, 2009 Share Posted March 21, 2009 on any type of setup with that steering geometry you can benifit by building a spacer to go between the rod end and joint. I have seen cutting board used with good results, and I have seen people use shock washers with a rubber grommet between them used with good success. Most people change the bushing out at least semi annually. Link to comment Share on other sites More sharing options...
trail grenade Posted March 21, 2009 Author Share Posted March 21, 2009 so do u think this setup is worth purchasing? Link to comment Share on other sites More sharing options...
wolfpackjeeper Posted March 22, 2009 Share Posted March 22, 2009 can't say, I do not have any personal experience with it. I can tell you that my cherokee is getting a WJ knuckle swap and will be getting all the JKS pieces needed to move it to high steering and a separate track bar. Lots of people run it though. Link to comment Share on other sites More sharing options...
