Need to know the bolt dimensions on the dana 30 ring gear!!!! Basically what is the dimension for center of bolt hole to center of bolt hole directly across?? Please if any body can go out to there shop with some calipers and measure this for me, I would say I would take you out to eat and buy you some brew-dawgies. But I'm sure none of you live in SC. But help a brutha out any ways!! :help:
The couple that I have out there are bolted to carriers.. So accurate measurements are not possible...
But suffice it to say that they are 5 1/4 to 5 3/16" ctc across the middle.
CW
Thanks man,
I went to the shop on my lunch break and measure my old ring and it was 5.25”. I made the spacer plate and it looks bomb diggadie! Thanks for your help though!
:cheers:
