phenryiv1 Posted February 17, 2009 Share Posted February 17, 2009 I am making the necessary mods to my 88 to use a 91+ grille and headlight doors (and yes, I am writing a how-to with lots of pictues). Before I install them permanently, I want to paint the parts, but they potentially have wax or grease on them. What can I use to prep the plastic that will not harm the plastic but that will promote good adhesion and an even coverage coat? Link to comment Share on other sites More sharing options...
jbhill Posted February 17, 2009 Share Posted February 17, 2009 i always wash plastic stuff with dish soap and a grey scuff pad if I'm going to paint it. cleans and lightly sands it. b4 i spray on plastic adhesion promotor, i clean it with wax and grease remover. Link to comment Share on other sites More sharing options...
brdhntr Posted February 17, 2009 Share Posted February 17, 2009 :agree: i recommend dawn dish soap to remove wax and wax build up. use a scotch brite pad to scrub it. when done, wipe it with rubbing alcohol (cheap). make sure you apply a plastic adhesion promoter. then paint it. with plastic, it's best to paint in lite coats. then apply the next coat when the previous is still a little tacky. when done, let it dry then sit in the sun for several days to bake it on. the paint will stick better and last longer. :thumbsup: Link to comment Share on other sites More sharing options...
