TPS Voltage???
OK,
Trying to do the TPS thing. Got the instructions that were posted here and not getting the results I need.
87 MJ Auto (actually the computer and sensors are all 87 Auto. The engine is an 01 and the AW4 is a 94) Ran well until about 3 weeks ago.
I'm getting 4.84 - 4.85 V on the input side. (Yes, I've checked/cleaned the grounds and everything. 4.85 is the best I'm gonna get)
When I change the leads to get the output side, I get 4.04 - 4.05 V.
But the part I can't figure out is that no matter how far I adjust the TPS the volts never change. Full deflection right, left, up or down the voltage stays at 4.04. Moving the little arm and it stays at 4.04.
Its a brand new TPS. Right out of the box and everything.
Why isn't the voltage changing?
Yes, I searched. Didn't see anything that looked like this.
