Tomahawked Posted September 27, 2008 Share Posted September 27, 2008 I have a new 91+ alternator that says is regulated by computer. Are the earlier 87-90 RENIX models basically the same? Will it work without any major alterations? I also have the right mounting brackets. Either use this new one, if can be easily adapted or spend money to buy the right alternator. Any insight will be greatly appreciated. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 27, 2008 Share Posted September 27, 2008 I have a new 91+ alternator that says is regulated by computer. Are the earlier 87-90 RENIX models basically the same? Will it work without any major alterations? I also have the right mounting brackets. Either use this new one, if can be easily adapted or spend money to buy the right alternator. Any insight will be greatly appreciated. The 91 alternators (Nippon Denso) were indeed regulated by the ECU. They can be used on the older models by adding an external regulator. There are a couple of writeups on it in NAXJA. Link to comment Share on other sites More sharing options...
