Red Dog Posted August 23, 2008 Share Posted August 23, 2008 My MJ had an aftermarket Jenson installed. I removed the door panel to find one black and one white wire going to the speaker. I have new speakers out of a '96 XJ with one purple and one blue with a red stripe going to the new speaker. Which colors correspond? TIA -RED DOG Link to comment Share on other sites More sharing options...
Red Dog Posted August 23, 2008 Author Share Posted August 23, 2008 Update: I took apart the speaker on the driver's side of the '96 XJ (the purple and blue with red stripe wiring was from the passenger side) and I noticed that the wiring on the driver's side was green and brown with a red stripe. Also, the black wiring had a narrow terminal and the white wiring had a wider terminal. Thanks again. :cheers: Link to comment Share on other sites More sharing options...
lostissues Posted August 23, 2008 Share Posted August 23, 2008 are the "new" speakers factory speakers or aftermarket? with aftermarket speakers the smaller terminal is the negative and the larger is the postive. this is the wiring diagram on the12volt.com: http://www.the12volt.com/installbay/ste ... /1210.html Hope this helps, Jonathan Link to comment Share on other sites More sharing options...
