Death Wobble Poll - Part 3
What is the THIRD most probable cause of death wobble?
36 members have voted
  1. 1. What is the THIRD most probable cause of death wobble?
    • Tire balance
      6
    • Worn/loose track bar
      4
    • Worn tie rod ends
      12
    • Worn ball joints
      0
    • Improper caster angle
      2
    • Worn control arm bushings
      8
    • Incorrect toe-in
      2
    • Other
      2
After yet another exchange on the topic of "What causes death wobble?", I thought it might be interesting to get some feedback as to exactly what our members think is/are the cause(s) of death wobble. I'm especially interested to see if there is any consensus, or if opinions are all over the map. Hence, a poll.
I don't see a way to do a 3-tiered poll, so this is Part 3 of three different polls. Please vote for what you think is the third most important factor contributing to or causing death wobble. Two parallel polls will ask for your first and second choices -- please be sure to vote in all three. At the end, I'll score the results. Each first-place vote will be worth 3 points, each second-place vote will be worth two points, and each third-place vote will be worth one point.
The poll will stay open for one week.
