Al Evitts
Everything posted by Al Evitts
  1. Al Evitts
    Dash pieces
    Anybody have a dash surround in the wooden applique they were selling years ago. { For the early dash} They closed most of the JYs here so not much place to look. Thanks Al
  2. Comanche is 88 model. It cranks slow and it takes a long time to start also. Battery is in goood shape. Thanks Al
  3. Does anyone make a high output starter for our 6 cylinder 4.o engines? Mine sounds like an old 40 plymouth trying to start in Alaska. Thanks Al startyer
  4. Thanks guys. I pulled up and out they came. really bad shape. Al
  5. How do you remove the rubber outside wipes on an 88 Comanche? I have tried search, and a couple manuals with no info. Thanks Al
  6. Inverse oiler is designed to supply MM,oil to the intake manifold in small quanities at idle or high vacuum and increasing the quanity as load is applied and the vacuum decreases. calibrated for approx. 1 Qt. per 1000 miles. Designed to provide upper cylinder lubrication as the work load increases. Al
  7. I have an old one of these that I last used on 79 Bronco. I would like to put it on my 88 MJ 4.0. Will using this thing cause any proplems with the EFI? Have a few different opinions locally. Thanks Al
  8. Got the Hush Thrush on today. Has a little throaty sound but no drone. I can now hear the radio. Thanks for the info. Al
  9. Thanks for all the info. I am going with a Hush Thrush or a Flowmaster 50. Thanks again the input was terrific. Al
  10. What is the concensus favorite muffler for the 4.0 engine. No drone but a good crisp sound \ Thanks Al
  11. Thanks guys. The box is square so that is my first clue. Some more closer inspection shows a tag that says "Made in France" I would guess its a Renix. Thanks again Al
  12. I have a complete FI set up from a Jeep {year and species unknown} Given to me. Is there any way to identify if this is Renix or MOPAR? Maybe the Computer nr. or something.Thanks Al
  13. .I saw a Cherokee in a parking lot with a wood surround on the dashboard. The sections had wood framework all around and the steering column was fitted with a wood collar where it enters the dash. Does anyone know who, if anybody sells these, they looked really cool. Al
  14. What did you pull up? I see the clips 3 to a side Do I pull up the clips or what/ Thanks Al
  15. I have an 88 MJ that has window scrapers that look like they were made of Graham crackers. I have some replacements but am not sure of the proper (easiest) way to replace them. Any help? Thanks Al
  16. Thanks guys. got a set ordered from TeamCherokee. a little pricey but they are supposed to be OE. Al
  17. Where can I get the outside rubbers for the Comanche windows ? Mine are brittle and about to go completley. Are new ones available? Thanks Al
