enigma94
Everything posted by enigma94
  1. Well, after looking at my track bar and comparing it to my friends stock track bar on his comanche we noticed that somebody(for whatever reason) decided to straighten the track bar where it normally bends. Which in turn made it longer and pushed the axel to the passenger side. :nuts:
  2. sorry for the late response, I had forgot I made this post. Well i double checked my track bar to make sure i was indeed looking at the right thing. The mounting points of the track bar appear to be stock and there is no sign of the track bar being modified so i assume its the stock one. does anybody have a measurement of the length of a stock track bar? maybe that will help....
  3. Yea, but what I'm saying is that adjustable track bars are made to eliminate the axle from being pushed to the driver side by the stock bar being too short. Well my Track bar seems to be too LONG since my axle is pushed to the passenger side. I don't want to buy a adjustable one and have it be even longer than the current one on there. Does anybody have any length measurements on a stock track bar, and also one of a adjustable one all the way (as short as it can go)? So i have verify 2 things, 1 that i have a longer than stock track bar, 2 if the adjustable one will correct this problem or only make it worse.
  4. Hello all, I have a 87 MJ with a 5'' lift and i'm having some issues with my track bar. Normally when you have a lift the axel should push to the driver side with the stock track bar correct? well mine is actually pushing to the passenger side. Its off by a good inch or so and the track bar does not look to be cut, and is not adjustable. I'm pretty sure its safe to assume I don't have a stock track bar so which one could it be, and what would you suggest doing to fix this usse? TIA!
