paully
Everything posted by paully
  1. Hello All! My first post here at ComancheClub, coupled with my first project with my MJ! I've a '91, 2wd, long bed, 4.0, ax15. The ring gear of the dana 35 rear axle (3.07 ratio) has given up 6 teeth (3 on opposite sides). So as I've read in multiple threads somewhere here, i'll "use any oppurtunity to upgrade from a D35". In an ideal world, this first project of many, will end up with: 1. a stronger axle, with d44 with 3.55 ratio is the ideal (if i can find one), with suspension over axle to gain a couple inches, 2. a front lift kit to match. Concerning #1: - What range of vehicles and years are recommended for an "easyish" transition? Expecting a little grinding and welding. My relying on local salvage yard dudes to help me find something compatible isn't getting me too far. - Anything I need to be aware of with the drive shaft for the various vehicles recommended? - Where can I find the gear ratio on the axle/diff? I'd read that it's stamped on the ring gear. But I'm not finding it on mine, which just states "6 2490 DANA 42828 P8L71 43 14". Concerning #2: - The couple of inches gained by the SOA trick from #1, needs to be matched up front. What's the "most economical" (i.e. cheap), but not risking reliability, way to gain these couple of inches? Thanks!
  2. jeep blabity blabity blar blar dana 35 blabity blabity ring gear blabity blabity
