MJUnderconstruction
MJUnderconstruction's Achievements
  1. Hey guys this would be my first time asking for help on here. So far this Form has Been a Huge help with My converstion along the way. Got a Some questions. 1. Using a AX15 Out of a 1998 wrangler and the Shift Tower doesnt line up with the Hole in the Cab. Is this normal? i havent found any post that says you have to Mod the Floor for the shifter. truck is on a drive way with a Slight down hill thought maybe the motor is saging back? 2. I used A 1991 Jeep cherokee Larado Auto Engine and Cab harness. THe inside Wireing was a Brezz with the help OF a few Post In the form. Only thing i can't figure out so far is why i keep blowing the Running LIGHT FUse. in the cab. all the Lights work. (flashers/brake/turn signals.) No RUNNING LIGHTS? :hmm: 3. THeres a Black wire running By the fuse box battery. and Alt. A/C. i thought it was a ground but when i put power connection snapped and smoked. the Wire seems to have a blue or gray or green traccer that i failed to notice. wire has a connection right by the under hood fuse box. i want say its a 10 or 8 gauge wire. Any Input and Photos would help out a lot. Just finishing rebuild on the trans and the need to have a rear drive shaft made. for the 231 sye. pretty much stock lift for now. Thanks Tons. Going to do a Write up when all is said and down. and She lIVes again. =)
