Mr. Smith
Mr. Smith's Achievements
  1. Thats absolutely correct. And I figured out too that I will need to make a intermediate support, but even with it the total length still will be less then the total length of a 2WD AW4. Do you think it's possible to find a 23 spline yoke from something? Also can anyone tell me what is the exact full length of a 2WD AW4. Thanks.
  2. thanks yall :cheers: As for why - it is a long shot in the dark. I want to install a AW4 trany in another vehicle but my space is very limited so the the full lenght 2WD AW4 won't fit. Then I had the briliant idea of using a 4WD AW4 transmission without the transfer case and just slide the driveshaft over the tail shaft - where normally the TC goes. But looks like this won't happend either becausse I want to use as newer as possible transmission and they all will be the 23 spline ones.
  3. What's the spline count of a 2WD Comaanche driveshaft slip yoke? Can you slide a 2WD driveshaft over a 4WD AW4 transmission output shaft (transmission output shaft, not the transfer case)?
