88wickedmj
    inman sc
  • Interests
    4 wheelin dirt bikes 4 wheelers and workin on cars
88wickedmj's Achievements
  1. can i swap the guages that have the tach in them for my factory non tach and the tach work
  2. i have a 1988 comanche pioneer i did a 4wd sawp on and my speedometer cable isnt long enough for the conversion i stretched it and it fit but i soon realized that the cable broke at the speedometer and i can't find a speedometer cable for it if anyone has one who could send it to me ill pay for it all mine has the plastic clip that holds it to the speedometer thats what broke please someone help me
  3. anyone know where i can get some bumpers for my 88 comanche pioneer i want a dual tube rear and a prerunner front
  4. will me having the chrysler 8.25 out of the 98 cherokee make a difference cause right now i have the stock wheels and tires on it and i have maybe 2in between the rear frame rails and the tires :hmm:
  5. i also have a 4.5 spring over lift from rustys offroad on it i was told that the wheels would make my tires scrub I'm going to be running 31/10.50/15 bfg mud terrains
  6. ive got a 88 mj with the chrysler 8.25 rearend and dana 30 out of a 98 cherokee i bought a set of 15x8 jegs baja 8's with a 3.75 backspace will these work on my mj or will they make my tires scrub on the frame
  7. hey guys I'm doing a 4wd swap on my 88 comanche pioneer and ive run into a problem i got the trans and transfercase from a cherokee but my drive shaft is too short i was going to use the one from the cherokee so is my stock 2wd driveshaft the right length or what if anyone knows how long i need to lengthin my chrokee driveshaft let me know please its the last thing i need to finish the swap
  8. hey yall my 88 mj i just recently swapped in a ax15 and np231 transfer case is there a way to adapt my 88 clutch master cylinder with the 98 slave cyl or will i jus have to drill my fire wall and use the 98 master cyl and all if anyone will help me out ill appreciate it
  9. yea i jus can't figure out how the linkage is setup
  10. hey yall. i did a 4x4 conversion on my 88 comanche pioneer and i lost my pics on how the 4wd shift linkage goes. Can some one please help me? the trans is a ax15 and a np231 transfer case, if anyone can help i would appreciate it.
