armygreenmj
    Bradford, PA
armygreenmj's Achievements
  1. Can you replace the rod bearings with the engine still on the jeep?
  2. Are the gas tanks the same from 86 to 89 in the comanches
  3. Thanks a lot guys for the help
  4. Can a short bed gas tank work in a long bed. The reason for asking it the short model tank is way cheaper
  5. Would doing add a leaf give any kind of lift without doing an soa?
  6. Thanks everyone for the replys I will try some of this out :wrench:
  7. I would like to fit 31s and to get Alittle ground clearance
  8. Can someone tell me a cheap and easy 2-3" lift for my mj I don't have the money to buy and expensive lift :(
  9. Ah ok had a moment there by no there's no drop on it
  10. It looks oily but it doesn't drip
  11. I have an 89 comanche with the aw4 tranny and when I go down the road and hit the gas lightly it seems to pop out of gear but if you hit the gas harder it works fine and fluid level is fine just wondering if its something that is an easy fix
  12. Yes I checked the fluid and it was fine but I haven't changed the fluid and filter yet that is what my next move was going to be I hope that takes care of it
  13. I have an 89 jeep comanche and it has the aw4 and when you lightly press the gas wile going down the road it seems as it slips and if you push the gas harder it works perfect just wondering what maybe the cause of this and if its fixable
