just need the motor must be complete why is this so hard to find will even take the whole truck does anybody have one located in Mass 02375 will even have it shipped if its a good one please let me know if anybody has one
PUT A 1999 4.0 Cherokee MOTOR IN A 1988 MJ WHAT GAS TANK WORKS THE BEST AND FUEL PUMP CAN I USE A STOCK COMANCHE TANK WITH THE CHEROKEE PUMP iANY HELP WOULD BE GREAT I WANT TO MOUNT IT IN THE SAME LOCATION AS THE STOCK COMANCHE TANK
TURNS OVER BUT won't START IS GETTING SPARK , REPLACED FUEL FILTER, HEAR FUEL PUMP TURN ON CAN SMELL GAS , AFTER YOU TURN THE KEY OFF YOU HEAR A CLICKING NOISE THERE IS A MOVEMENT BY THE ACCELERATOR CABLE GOING BACK AND FOURTH ANY IDEAS
driving me crazy sprayed some quick start in fuel injection runs for about a 2 seconds then I hear a clicking noise seems like it wants to start just replaced fuel filter the old one was full of gas could it be the lines from the fuel filter to the fuel injection any help would be great
my 2.5 $#!& the bed can I keep my aw4 transmission if I put a 4.0 in it if so what year 4.0 will fit and what else do I need wire harness and computer motor mounts ?? I want to keep the 4spd because I just put a new clutch also will my transfer case work with the 4.0 any help would be great forgot mine is also a 4x4 thanx
Have a 1988 with the 2.5 the radiator was replaced with 4.0 radiator they also took off the fan and the clutch on the motor and I guess the were going to rig up just an electric fan mounted on the radiator problem Iam having is when I start it up temp goes right up to about 220 really quick just sitting in the driveway I have not hooked up any fan at all whats the best way to fix this whole mess
How hard is it to put new floors in and can you by the new floors if so where no rust anywhere else just the floors someone did a patch job already with sheetmetal did a crap job
