Masiro
Everything posted by Masiro
  1. The rod from the ignition switch to the key cylinder is working but no return action is in it. The ignition switch moves through the whole range of motion but does not start the jeep as if the switch was bad in the start position and it is not.
  2. First let me say that I am pretty good at electrics, but somehow in the rebuild process something went horribly wrong and now my comanche won't start. it seems like just yesterday (actually last week) the steering wheel broke at the mounting plate, (look ma no loose screws) and the steel tube sheared and I was left with a dangling steering wheel in my lap. I pulled the steering column out completely, disassembled it, welded the broken pieces back together reassembled it and put it all back in. I got power with the key and I am reasonably sure the ignition switch is properly adjusted to the right position. I also don't feel the start return to run when I release the key. it just won't start and acts as if the starter solenoid is not getting power, I confirmed this by crawling under and shorting the starter and baw it starts. 1989 Jeep Comanche pioneer with a 4.0 litre and a 5 speed
  3. :jump: A Part Number and a couple of GREAT links. Thank you sincerely from the bottom of my heart
  4. Hi, I need a brake release cable for my 1989 Comanche BADLY. I set my E-brake and have to release it by hand
  5. shrink it to 150 by 150, and then post it on tinypic copy the link to it and put it in your link to an off site image
