JeepSRT8
JeepSRT8's Achievements
  1. Does anyone know of a compatible driveshaft for the rear? Its not a big deal to get one altered, but if there's a compatible one that would make things easier.
  2. Thanks. I guess I shouldn't have any issues then, aside from figuring out what to do about the driveshafts that is.
  3. Thanks! I overlooked the wheelbase issue so thanks for bringing that to my attention.
  4. I just bought a 91 comanche 4.0 HO, 2WD. I found a 98 cherokee 4.0, 4WD donor. Off the top of my head I'll need the transmission, transfer case, front and rear driveshafts, 4WD shift selector, front axle, and I'm assuming the main wiring harness to accommodate the trans/transfer case. So my questions is, will I encounter any problems since the comanche is a HO and the cherokee is just a regular 4.0? Also, is there anything else I should be aware of or require? I also plan on taking the grille to update the front end appeal. Thanks.
