doc_dyer
Everything posted by doc_dyer
  1. found front grill at pullapart painted flat Krylon camo black whole truck is Krylon camo tan shot of the interior a little paint work on the bed one cancer spot to work on above fender but overall great paint job for trail truck
  2. cut new dash tabs and welded into place drive train removed and ready to install going in donor engine bay looking empty almost done
  3. installed the heater box all the holes lined up except one drilled new hole and in it went relocated the e-brake used tape to copy location of bolt holes drilled out support bracket from cherokee and tacked it to the comanche
  4. new comanche to build on
  5. donor 9 XJ workshop ignore the comanche on left, found another one for 200 that had floor fixed and was painted
  6. well been lurking for a while, getting close to being done with my comanche so I thought I would start a build thread pics to follow
  7. thanks what about the front, brake lines?
  8. where can I find e-cable extensions or what do I need to look for in the junkyard to make these longer, or find longer cables Thanks, Bradley I have 2 front and rear axles sitting around that are both 4.10 if you were wondering why ;)
