InvitedChaos
Everything posted by InvitedChaos
  1. Don't let the name fool you - this little guy is in need of some serious TLC! Bought in January, put in new battery and sparks but still had to jump the solenoid to limp it home on 5.5cyl (cyl 6 kept cutting in and out, seems to be a short in the wiring harness). Frame looks to be in pretty excellent shape, and tires are relatively new (only about 300mi on them, allegedly). This thing has: - 82k original miles - No heat pump - No rear bumper - No exhaust - No working dash gages - Incorrect fuel injectors - Bypassed coolant reserve - A half-detached bench seat - Drooping head liner - Frozen hood hinge - Painted-over chrome trim - Awful LED headlights, and - A crappy paint job that allegedly cost $2700, but was clearly done without sanding or a primer coat and is already peeling/trapping rust. I'm determined to get it back in respectable driving condition! Ideally, it'll be my daily driver and short-range camping vehicle. First up: - Unfreeze hood hinge - Determine whether the BMW injectors installed are actually detrimental or just non-ideal, and figure out if the system can adequately compensate - Buy and install a heat pump - Route new tubing to reconnect coolant reservoir - Redo the crappy wiring harness repair for injectors on cylinders 2 and 3 and inspect for damage on 6 - Troubleshoot gage clusters and repair or replace - Get it to my godfather's shop so we can put it up in the lift and check out the overall structure Wish me luck!
  2. Picked this one up in January from a guy who probably had good intentions, but not the best judgement or execution. 1988 Comanche Inline 6cyl 4.0L Allegedly came from MN, previously registered in MA, now residing in VT Door sticker has been painted over.
