Now swapping in an (external slave) RWD AX5 from a 2000 XJ. Also installing a Core Shifters short throw.
Had to splice the clutch lines together. Used the factory clutch hose. Found an adapter from 7/16-24 to 1/2-20. Then 5/8 steel line to compression fitting to the external slave nylon hose.
had to swap to the cable driven speedo housing from my AX4.
using factory 1988 Clutch master cylinder
Everything else looks the same. Not finished yet. Maybe finish it up tonight.
