SLOTMAN
Everything posted by SLOTMAN
  1. Thanks a lot for all the suggestions a lot to think about and research before I make a final decision
  2. It's on 33 inch tires what gear ratio do you think would be appropriate I was thinking 488 because of the lower torque of the four-cylinder motor versus the six and having the OverDrive 5th gear would allow it to do some freeway driving still but will 488 fit in the stock pumpkins it already has posi in the rear and do you think it would be worthwhile to put some type of posI in the front while it's apart and if So what kind
  3. What are you looking to get for the cluster and do you have a photo? also some information on how to set it up, what sensors you would need to replace, maybe some part numbers? is it plug and play mostly? if you have that information it would be appreciated
  4. Thank you for the reply sounds like good advice I'm also gonna check water pump and thermostat probably replace all three plus hoses to get the job done right
  5. Thank you for the reply much appreciated I'll probably be looking for a 1986 gauge cluster in the future we're aftermarket separate gauges thanks again
  6. How do I check to see if they're working especially the heat gauge light don't want to overheat and the light not coming on because it isn't hooked up or sending unit is bad how do I check each gauge that is truly working as it should any help would be appreciated
  7. Is there an upgrade radiator with maybe two cores instead of 1 that will bolt in being as I'm changing out the radiator if there is one, company to get it AT and part number would be appreciated also I think an electric fan for slow crawling would also be an appropriate upgrade any thoughts would be appreciated thanks in advance.
  8. Actually if you Google reviews on when this truck came out many will state that short people will have a hard time driving this vehicle and that it is a factory problem it just doesn't go forward enough I was just wondering if in later years new brackets where something was done to address this problem if not are there any mods on this form to fabricate parts to correct to correct this problem I don't want to reinvent the wheel if someone has done it successfully I can just copy it if not I will do a fabrication fix and post it on the form since there may not be any on here
  9. It amazes me that there are not more short people on this forum that have run into the same problem with mods to fix it not to mention 5 foot women that it would almost be impossible to drive this truck not to mention being dangerous by not being able to reach the pedals properly
  10. the seat moves it just won't go forward enough for me to reach the peddles it has been stated that this was a problem from the factory bad design
  11. short person is there a mod to make the bench seat go forward more
