livinjeep
livinjeep's Achievements
  1. ahhh, I see, so its the $200 ones on ebay lmao. definitely not what I have, but I know what i need now. Thank you so much for your help and picture!!!
  2. Hey y'all, I'm looking for help trying to figure out the correct crossmember and/or trans mount setup. So I have a 2wd 87 comanche with 4.0, and it used to have the AW4. I pulled the AW4 and swapped in an ax15 from a dakota, obviously the mount setup and rear housing weren't near correct. I bought a jeep rear housing ax15 and rebuilt it, and went to install it and I'm running into trouble. I bought the correct manual transmission mount bracket for the ax15 for the comanche, and what I think is the correct trans mount, but I'm not sure if my crossmember is correct. I work at a chrysler dealership, so I have access to factory part numbers, but no pictures. I believe I have the 52002328 crossmember, but can't be sure because I have no pictures to compare to. Google brings up what looks like the same crossmember for both 52003929 and 52002328 part numbers, unless they're just similar and I can't see the difference. Anyone have a 2wd ax15 comanche that I can compare pictures of your crossmember?
