AllenT9
AllenT9's Achievements
  1. 86 MJ 92 ECM and harness 95 4.0 After months and months of repairing rust, rebuilding the 4.0, getting things set up the way I want them. My ASD relay latches in and out. I'm running 2 batteries in parallel, replaced/repaired all grounds, eliminated the fuel pump ballast resistor, cut the latch signal for the ballast resistor bypass relay (not needed with 12v always going to the pump). I've confirmed good battery voltage and ground at ECU. Battery voltage and ignition voltage at ASD relay. The ECU should provide ground to the ASD coil to close it and activate the relay. What I found was a pulsing ground signal from the ECU to the ASD relay. I've Unplugged all loads the ASD relay feeds with no change. At this point I feel it's down to the ECU and a bad capacitor. Any other ideas or thoughts?
